Thanks Dude!Another option, and with Costco installation is DIY
The Costco AGM is probably the red top Optima battery and not the more powerful yellow top but good enough.Thanks Dude!
I really like Costco and try to buy there whenever I can. Their return policy, extended warranty, U.S. based tech support, and prices can't be beat.
They generally sell good quality products, so there are probably no worries with their AGM batteries. Just out of curiosity, I wonder who makes them?
<Later> Here's one answer: https://vehiclefreak.com/who-makes-costco-kirkland-batteries/
I am not sure. See the FAQ Section of the article and I’ve also seen that Interstate makes Costco's AGM Batteries as well as other manufacturers supply Costco with AGM Batteries so not sure.I didn't see anything. I believe Clarios makes it.
Interesting. Hope so as I have the "A" suffix also.2023 Heritage trim here. Picked it up a couple of weeks ago. Mine has the BHEF-48H6-A lead acid battery.
Note: the -A suffix that appears, versus some of the battery photos in this thread . Wonder what the difference is. Looking at the Motorcraft parts website, the -A version replaces the other stock number.
Perhaps improvements in construction and/or chemistry, to address prior issues?
AGM is of course a newer (not "new") design, but is still a lead acid battery. My BL built December 2020 has the conventional 700A battery. I don't think I've ever replaced one without noticing degraded performance first, but replacement is normal to expect after a time. But, you can spend more on an AGM and less time and effort replacing them.The OEM battery in your vehicle was supposed to be an AGM battery. I have a 21 OB and it was shipped with the AGM battery.
Ford had supply issues and could not get enough AGM batteries for the Bronco Sport and had to start using conventional lead acid batteries.
Can also just be a different vendor for the battery. Ford doesn’t generally state what the change is when a part number is changed.BHEF-48H6-A lead acid battery.
Note: the -A suffix that appears. Looking at the Motorcraft parts website, the -A version replaces the other stock number.
